Suggestions for brushless Jato...
orangecrush
Suggestions for brushless Jato... - 03.04.2008, 11:14 PM
Well now that the Revo is 99% done, I've decided to convert the jato.
I bought a buddy's Jato that had less than 1/4 gallon through it. He's replaced about everything on it with upgrades and with all that, ez start, extra wheels and tires and absolutely flawless condition, I only paid 200 bucks.
I pulled the engine with ezstart motor and pipe and put it on ebay. Right now it's at 113.00 bucks with 6 days left. Hell, I'll almost have the Jato paid for...lol.
Anyway, sorry, got distracted, I installed a RC Monster motor mount I pulled from the Revo. It was flexing and I don't think it'll flex so much with a lesser motor and battery.
So, what size motor and which controller would you suggest? I want to run a 3S battery (5000mah). I was actually thinking of getting a VXL motor out of a Rustler or Stampede. The VXL's I have now simply fly... Do you think that would be enough?
Thanks in advance for everyone's suggestions.
Mark
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
03.04.2008, 11:48 PM
There is a Jato Forum area in the main Forum menu. You might look there for more info. Most peoples opinions, mine included, is to sell the Jato and buy a 4 wheel drive setup. maybe the CRT .5. They are selling for about the same as the Jato on Ebay. But so times you just want to build something. I did with the Jato. I would shoot for a motor with about 3200kv or around there. Plenty of speed and torque. I only run MM's so far and they are a good solid cheap ESC. My set up was Lehner 1920\7 with a MM on 3s2p 8000 mAh lipos. It was nice but way to fast to control. At about 53 mph the front end was so light it would lift off the ground. No control with only 2 wheels on the ground. Just my 2 cents.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
orangecrush
03.05.2008, 12:22 AM
Well color me stupid... there is a Jato section. I must be blind. I agree how the Jato will be uncontrollable... My Rustler VXL is ridiculously the same way and at 52mph on radar, I simply couldn't get it any faster because everytime I'd gently pull the trigger, the car would wheelie up even more. That was on about a just about an 1/8+ mile strip.
Anyway, thanks for the opinion and correct forum section.
Mark
orangecrush
03.05.2008, 12:30 AM
Would a mod mind moving this thread to the Jato section please?
Thanks.
Mark
Hickoryhead
RC Wanna BE
03.05.2008, 01:32 AM
Mark
I hear ya there. I had to run a 19 tooth pinion to be able to use the full throddle. That kept it at 48 mph. There really is nothing you can do to stop the front end from coming up. Might just be me but I think it has a lot to do with the air flow going under the body. I had a rustler that I put a bandit body on with the same set up except the motor was a lehner 3100. The gearing was messed up but I just wanted to do a speed run. I only got one run out of it. I am not sure what the speed was but it was moving. I had it way out away from me coming in. As it got closer it started to slow down and stopped all together and something smelled like buring wires. I walked over to it and poped the body off. Every solder joint from the battery to the ESC have undone itself. Thats some heat. Airflow is good for something I guess.
03.05.2008, 10:36 AM
Yeah, the way the front end is shaped does make it easy to flip, but if you try to put the batteries towards the front (or center) it helps with the lifting. If high speed is what you're after, I'm sure a front spoiler can be easily be made with Lexan/plastic/Al sheet/etc and mounted somehow.
The problem I had with mine is getting the rear wheels to hook up, especially on dirt. Most (if not all) ST have the motor behind the rear wheels so it helps traction.
Are you going with the single speed or keep the two speed? Just like the Revo, you'll need mech brakes (and won't have reverse) if using the 2 speed. What's nice about the Jato is the availability of the single speed, which eliminates the need to find a way to lock it into second gear.
Good luck! Oh, and pics are mandatory!
PowerRocks
03.05.2008, 06:18 PM
If the Jato has such a hard time keeping the front end down, then how do the nitro ones do it with an advertised speed of 65 MPH?
orangecrush
03.05.2008, 08:39 PM
Brian,
You got man, you hit the nail on the head with that... too much air getting underneath. I know this because when I had the Rustler as a Stampede, it was ridiculously fast but air kept getting underneath it. I converted it to a full Rustler but left the height at it's highest and it was better. I lowered it and it was even better. Aerodynamics make a big difference even on a small rc car..
What do you mean "availability of the single speed"? Is there a trans I can get that I don't have to lock it into second gear? That's what I was going to do... the same mod you showed us for the Revo.
PR,
I don't doubt it's possible but I think it has to be under ideal conditions... long track, slow squeeze, etc, etc...
Like I said, I got it to 52 and had plenty of throttle left.... I just needed more room and I'm sure I could have squeezed way more out of it.
Mark
MetalMan
MetalMan's Avatar
03.05.2008, 09:11 PM
The wheelie bar plays a huge part in keeping the front end from lifting up too high. Compared to electric, nitro has less torque, so it's also less likely to wheelie than its electric counterpart.
03.05.2008, 09:15 PM
Yeah, there is a single speed conversion available. The ratio is just about halfway between the original first and second gear (the ratio is included in the speed calc). It eliminates the OWB/first gear and the centrifugal clutch, so basically does the same thing as when modding the Revo tranny. Of course, you can mod the tranny in a similar fashion, but much easier to get what's already out there...
BTW: I did a Jato as well, here's the thread: http://rc-monster.com/forum/showthre...hlight=project Started as just an on-road project, but I got sidetracked.
orangecrush
03.05.2008, 09:45 PM
Brian,
I bought a 5700 Mamba max and controller today. I ordered a 5mm 1.0 pitch pinion gear with 3.2 adapter from Mike today because I want to use a revo spur gear.
I'm ready to get this going...
