04.16.2008, 12:13 AM
Alight, heres a good looking pack
http://www.b-p-p.com/proddetail.php?prod=ab_H800
20C, but the MAH is only 800, so I could do this
6,000 KV motor on 800MAH 3s lipo
Or a 7,300, or 9,000 KV motor with a 2s lipo, and hook them up in series, so its 1600MAH
What sounds like a better deal? I need the run time, but 60 bucks for two 3s packs is insane!
04.16.2008, 07:08 AM
I use the TP2000 3s in my MLST with a 7000kv motor. Loads of fun. That battery has held up great for 2 years as well. Worth every penny IMO. Is that battery too large for your app ? If so, i'd go with the TP 1320. 800mAh seems kinda small. If you did them up 2p though, you'd have 1600, which would be decent.
J.
04.16.2008, 10:14 AM
Yes, I need a batt thats around 31mm wide, the hyperion is 34, but thats not bad
Only thing is, is 2p will be for 2s since I highly dont think the bottom deck to the top is over 20mm, so I will probably have to shim the top deck, but thats no problem
Certified Spaceball
04.16.2008, 12:14 PM
I use this in my 1/18th rides:
http://2dogrc.com/ecommerce/os/catal...nt-p-2177.html
Its a little longer than what you are asking for, but very close. If that is too long, then try this:
http://2dogrc.com/ecommerce/os/catal...nt-p-2175.html
Out of curiosity.... will your track allow 3s? Are you going to be running with other 18R's or trying to race in a 1/10th class with your 18R?
I like the look of the new novak motors, but the kv ranges have me worried. The kv's seem way too high for actual 1/18th sized tracks. I'm currently running a Hacker 4200kv motor in my rc18r, and its plenty for a normal sized 1/18th track. People try to run mamba 8000kv's on the track and they are all over the place. You know a noob has shown up when he busts out the 8000kv motor for a track that only has a 25 foot straight...
rcm xt8
rcm xb8
rcm crt.5
04.16.2008, 06:52 PM
Those look good, but a bit to wide, im really looking for a short narrow pack, I dont mind buying 2 of those hyperion packs and wiring them in 2P.. But a good choice for sure!
When I race, it will be with 6 cells and a stock 18R motor, this is to have some cheap fun with while my TC is charging. I race 10.5 or MOD sedan, so no on the racing 18R with them lol
I love the range of KV, My back straight is 164 ft!!!! Y E A H ! NEED motor lol my track is darn big, and theres a perfect sweeper at the end of the straight, so motor is def needed, and with the mongoose being a 380 can, it should be a torquey motor, So im hoping I can gear it pretty high, in case I need more speed
Certified Spaceball
04.16.2008, 07:52 PM
Ok, that makes sense.
How about this one. Its pretty narrow:
http://epyaya.com/product_info.php?c...oducts_id=2531
rcm xt8
rcm xb8
rcm crt.5
04.16.2008, 09:40 PM
Man, how do you know of all these LOL?
I like that pack! Id run that in 1P, so I think id do 3s, its illegal any way with lipos, so might as well have a efficient system right?
I think I might try those out! Thanks!
Never Fast Enough
04.16.2008, 10:22 PM
rschoi is the king of 1/18th scale from what I've read ...
04.16.2008, 10:24 PM
Possibly
I see him posting on one18th alot, im Money is the Key there BTW
04.17.2008, 07:54 AM
04.17.2008, 08:28 AM
Originally Posted by lincpimp
Unless neu make a small high powered motor!
Neu 1100 series are pretty close to 280 size - theyre 29mm diam. I was thinking of getting an 1107/1.5Y for my MLST2, and maybe an 1105 for the mini-t.
Probably wont have a whole lot of room for the gearing with a big motor like that though, and thats assuming the motor holes line up the same.
04.17.2008, 08:33 AM
With the 54T spur, the smalled I can fit with the Mega ACn16 is a 27T pinion. I didn't try my Neu 1107, but you can try a 29T or 30T pinion.
04.17.2008, 10:40 AM
04.17.2008, 11:11 AM
The 11xx series of Neu motors has 16mm mounting holes, so they'll line up just right.
Also, FWIW, an 1105 would be way overkill in a Mini-T. It's not too hard to even run a Mamba motor in a Mini-T without temp issues. Heck, I've run a Mamba 6800 in my RC18T without temp issues...gearing is a huge factor with those little motors.
