Originally Posted by tc3_racer_001
hmm. id love a link to that guide!
so i can use my pc power supply, and use metres of cable to limit like that? id want a 10A charge rate max, but with only 12v, but would it be possible to charge 3s via that, or would it charge it too much, over 4v... id need a cutoff. a link would be great, as i could test it out before buying the chargers!
ryan
I have used computer P/S to charge 3s packs. I use a longer cable to try and hold the starting charge to 8 amps. My supplies are rated to 10 AMPS. I use this cutoff device, With both deepcuycle and P/S as input source. The only difference is I use about 5' less wire when I charge from the Deep cycle.
http://www.rcgroups.com/forums/showt...highlight=A123
Highflier
