Pdelcast
Pdelcast's Avatar
05.08.2008, 05:34 PM
PdC any update on the motors - winds, specs, thoughts on factory or local food?
**gger - BrianG can you correct my typing of China!&*!%^*!
China summary -
Factory adding capacity every day. By end of June factory should be at double April capacity.
Worked through several issues with 1515 rotor assembly and balancing. 1515 nearing production, but still some issues to work out with getting consistent quality on magnets.
1515 motors dyno'd very well, Kv at 2150 RPM / V. Ran several batteries on Emaxx with 1515/1Y (6S setup.) Found motor requires cool down between each run, maximum motor temp was around 85 degrees centigrade (29 degrees ambient) This was a VERY heavy setup with 10AH 6S battery.
Local food -- really good fish called "skinless cow fish" (direct translation) Anybody know the English translation? Ate way too much Dim Sum...
Patrick
