Originally Posted by johnrobholmes
I actually have a crawler system I am not using if you want.
The way the novak is set up, there is no drag brake. You hit throttle and it will coast if the slant is steep enough. It hits the brakes at neutral, so there is no proportional brakes. This doesn't work well on steep slopes, as it will coast until you let off- then it slams on the brakes. Some people like it, some people don't.
Interesting, was wondering if you think the crawler esc would work with a 13.5 motor? It looks just like the xbr with a different programming/profile.
