Finnster
KillaHurtz
Finnster's Avatar
08.25.2008, 02:13 PM
Ryan - The speed runs 48mph at the end were on 4s 5000mah c**pamps... I think that 4s on the 3300 would be ok with just gearing it down a touch...
12T would give you 42mph
O'rly? I thought it was your 3S packs
Oh well.. I'm suprized it was wasn't faster then lol. It could prolly take a lot more gear. When I did the 60mph passes w/ the LMT I had a 18T pinion and 1/10th buggy tires. I was actually only pulling 1000W then. With the M2Ks on a 13T or 14T I was pulling 1400W on the LMT and doing just under 50.
Right now I have a 13T w/ the mashers and the Medusa and it runs really well. OTOH I had the buggy tires on w/ the 13T at first and it was a bit slow, about 35-38mph. Wouldn't wheelie either. Putting on the bigger tires (and bigger load) really woke the motor up. I think it needs a 15-16T for the small tires, and a 14-15T for 1/10 truck tires to run well.
So it sounds like either would work, assuming the 3300 stays cool w/ that high FDR. (sounds like it does) I do guarantee that 3300 will be balisitic if you up the gearing.
