09.14.2008, 12:56 PM
Originally Posted by rckcrwlr View Post
I am just using the stock set up...They are adjusted all the way out...I will probably preload them a little in the front to eliminate some nose diving but the rear are perfect...it handles exactly like a CORR Truck...
Ok, but what color are the stock springs? They should be mainly red with little spots of color on the ends. Usually the front and rear are different colors...
09.14.2008, 01:23 PM
I think stock setup was silver up front and green in rear. I may be mistaken.
09.14.2008, 06:15 PM
5433A Spring, shock (red) (GTR) (1.4 rate double pink stripe)
5434A Spring, shock (red) (GTR) (1.6 rate double blue stripe)
5940 Spring, shock (red) (GTR) (1.8 rate double green stripe)
5941 Spring, shock (red) (GTR) (2.0 rate double black stripe)
5942 Spring, shock (red) (GTR) (2.3 rate double purple stripe)
5427 Spring, shock (white) (GTR) (front 0.7 yellow) (1 pair)
5428 Spring, shock (white) (GTR) (front) (0.9 rate orange)
5432 Spring, shock (white) (GTR) (front) (1.3 rate gold)
5429 Spring, shock (white) (GTR) (rear) (1.0 rate tan)
5431 Spring, shock (white) (GTR) (rear) (1.2 rate silver)
5434 Spring, shock (white) (GTR) (rear) (1.6 rate blue)
5430 Spring, shock (white) (GTR) (std. front) (1.1 rate green)
5433 Spring, shock (white) (GTR) (std. rear) (1.4 rate pink)
5998 Sway bar kit, Slayer (front and rear) (includes front and rear sway bars and adjustable linkage)
Weird how they list 5430 and 5433 as the std springs, but 5433a and 5434a are listed in the exploded diamgram as the stock springs. The pictures show red springs, bit i wonder if I can use the white springs with the same rates?
rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
09.14.2008, 06:19 PM
These are the stock one's on the Slayer...
Bought my Wife a Rock Garden :027:
xcntrk
xcntrk's Avatar
09.15.2008, 08:55 PM
The stock slayer spring color is PINK in the front and BLUE in the rear.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
