cheesecake
10.30.2008, 04:03 PM
i bet thats some sort of circuit board protection that melted into a oily substance when it got that hot
Pdelcast
Pdelcast's Avatar
10.30.2008, 04:18 PM
Don't think that's the case -- we use a silicone based dipped circuit protection (called "conformal coat") doesn't turn back liquid until 600 degrees --
Looks like something (oil, water) got in the case -- sucked in by the fan.
Patrick del Castillo
President, Principle Engineer
RBMike
RBMike's Avatar
10.30.2008, 04:38 PM
Ya, I've been using conformal coating for years & the only time I've seen it look like that was after the product had been dropped into dirty sea water.
bustitup
10.30.2008, 07:06 PM
It looks like sand/water found its way in through the various small gaps in the case. No ESC I can think of will be immune to this unless the circuit is encased in a watertight box, or maybe a epoxy blob...
brian its not water...its oil or grease......I was running on pavement with phaltlines and it was only for about 10 or 15min
bustitup
10.30.2008, 07:09 PM
after the run when I first pulled the esc out of the truck ....when i was handling the esc I could feel this oily residue on the outside of the case
bustitup
10.30.2008, 07:11 PM
that was the feeing i had when looking at it .....and when i peeled off the sticker to get to the bottom of the case....the under white side of the sticker has what looks like tan (rust color) oil stains...and it even smells a little like oil
entjoles
10.30.2008, 07:17 PM
did your battery vent ? do they look good still ?
sounds like the stuff inside a lipo to me
j/k , was hoping someone would jump onboard with me on this
kostaktinos_mt
10.30.2008, 07:59 PM
could be capacitor electrolytic fluid...
check the caps to see if any has popped...
just a thought...
  Send a message via MSN to kostaktinos_mt
e-mike
e-mike's Avatar
10.30.2008, 08:06 PM
just a thought...
i think that me too ...could it be the capacitor!!??
D8t on juice!!
coreyfro
10.30.2008, 09:23 PM
I work at Moffett Field in CA. I have runway's for C5's JUST down the street. I keep trying to figure out who I talk to about making speed runs, or if I should just make one or two without permission, on a Naval Air Base. I've always wanted to visit Leavenworth this time of year.
Originally Posted by castlemike View Post
We only let him drive when he holds that "I'm the owner of the company" thing over our head. We did figure out that doing 60+mph speed runs in a small parking lot full of cars is kinda stupid. I have had to replace the front end on our RC8 conversion 3 times in the last couple of weeks.
mxracer
10.31.2008, 06:51 AM
looks like a nitro car still ,, oil / crude everywhere ..
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
cheesecake
10.31.2008, 03:28 PM
im going to rip my v3 apart i remember feeling something oily on the case when it arrived and i bet by now it has settled.
stum
11.01.2008, 12:27 AM
I wouldn't gear a 1.5d over 22/58 for regular use.. maybe a bit more for speed runs and such but if you are doing some serious bashing or racing that is the MAX. Racing is best around 16-19t/58 depending on your track size/layout. Typically being geared right on or just under 40 will result in the best lap times. I'll agree those packs coulnd't handle the amps you were pulling, and it resulted in the failure. Gear that thing lower.. specially considering the packs you are running.
e-mike
e-mike's Avatar
11.01.2008, 12:50 AM
stum...do you run a new e-revo?????because i run a 1.5d(1515)on 6 cell in a new e-revo and im geared 14/68.....its really fast....(i guest).
D8t on juice!!
stum
11.01.2008, 12:56 AM
Yes I have the e-revo
You are at about 45mph with that gearing on 6s, but your RPM's are at the max 60k line..
22/58 on a 4s setup in the erevo is about 54mph on the top end.. considering the 4s 8000mah is the longest running config of any (no matter the voltage) due to the battery tray limitations I always stuck w/ 4s in it. (though a 5k 6s (2x3s) setup is pretty close, just more $$'s)
16/58 is nice for racing ~40mph on 4s (rpms at about 40k)
