No, I didn't misread. I know it's a bit higher than most people normally run, but it'll work fine. Someone posted efficiency graphs on the Neu motor and they hold pretty good efficiency up to around 57k rpm. As long as the gearing is kept reasonable, amp draws would be about the same as a lower rpm motor geared higher. The amount of work doesn't change, just how you get it...
