Carraig042
11.24.2008, 08:18 PM
Both of the candidates in this years’30 presidential race are great choices, but I think that McCain will be the better of the two.
If I used those, another good idea, They will have to be 3mm sized threads. I might look and see if I can't come up with something.
the esc can melt a big hole into the top of your batts while you frantically try to remove it from the chassis
The bottom plate should help with any problem like this... Hopefully
-Brett
