castlemike
12.04.2008, 06:51 PM
Originally Posted by Thomas Porfert View Post
joeling,
If you carefully press the tabs in on 2 or 3 sides of the case, the case will simply pop apart
Castle Tech Support
This would be incorrect.......do not insert anything into any of the tabs on the sides of the controller. Pop the tabs loose on the motor wire side, and the power wire side only. The tabs on the sides are off limits when it comes to pushing them in. As long as you do it from the ends you should be fine.
