TruckBasher
TruckBasher's Avatar
12.04.2008, 08:08 PM
Thanks for this information. Me and joeling are on the opposite part of the globe and getting in touch with CC in any form is very helpful.
On a side note, i tested my 2 V3 that I received as a replacement for my V2 however one of them wont arm/sync with the controller:
- holding wide open throttle, will hear tones followed by 3 tones (like setting the full forward throttle) but then it will stop if you go with full reverse and just blink amber
- Similar symptom as the V2s I've sent to CC
- Re-flash to 1.20 see if it helps but nothing same result
- Swap the 2nd V3 and everything work fine. Nothing was changed except the V3
Does this mean I got a bad V3? I am about to send it back to CC with the Invoice and original receipt.
Any suggestion to make it work will be appreciated. The video of the 2nd V3 working flawlessly can be found on the 2nd link on my signature.
Joe Ling let us know what is rattling on that V3...hope everything works
E-Slayer direct drive to diff
