The HV110 ESC doesn't have that soft start issue you are speaking of. Well, it can if you set it that way. My HV110 had just as much oomph as the MMM on my GTP.
Yeah, if the settings are wrong, there could be a lot of low rpm slip. But I wouldn't think it would be an issue if not even using a clutch spring at all.
