zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.07.2009, 01:12 AM
Ah, okay gotcha... he is right as well, you need less "total" energy when you increase pack voltage. Higher C batteries will also give more energy than a lower C batt, simply because the voltage is higher under load, less throttle pull = less mah pull from battery.
