fletchoman
07.20.2009, 02:16 PM
All you would need is a 1506 Neu for a Rustler, which can be had for $130 for a 1506/2.5Y/S at ImpaktRC right now.
Yeah, I bought a 1509 for my Rustler from ImpaktRC...Make sure you get the smooth can because the finned one doesn't fit if you are still using the stock transmission case.
Mod-1 is doable but it does limit the pinions that can be used...I find that the 64p gives more and better gearing options...I have had far more problems with the drive shafts when I used the Neu.
