florianz
08.29.2009, 05:59 PM
I've seen small capacitors do ok, but I like higher and more capacitors just to be safe incase one fails. If the warranty is good for them, try it out. That will be the only real way to find out if it'll work out good.
I don't want to void the warranty, but I'll do it in a way that I can reverse it w/out a problem.
my plane esc's were very smooth and never exceeded 35 degrees c.,w some extra caps (at least doubled the capacity of uf).
for boat esc you can get massive cap banks, eg. by etti or yge. when its good for boats, it should be good for cars, too. especially, as we have higher peaks, and more partial load, different to boats. they have higher permanent amps. but not such high peaks, especially when breaking.
florian
