Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
09.22.2009, 10:54 PM
Do you have the motor plugged in? Properly? Maybe try plugging in the battery with the turorrle held all the way down on the transmitter. Have a separate bec plugged in?
Don't know why I'm saying all this... Doubt you're doing anything wrong. You're experienced enough. Wonder what castle says.
Edit- Looked at the led meanings sticky in the cc forum. It only says it's for car controllers, but it might be somewhat universal. Solid red or green means full throttle or reverse. Doubt the little flash of hape you got was that, but it might be. Maybe you have the rx plug plugged in backwards?
i will check the led meanings. i have checked and re-checked the to make sure its plugged in right and polarity etc. i cannot see anything i am doing wrong? i wish it was something i am overlooking so then its just a quick fix but it seems to be a problem with the esc. i mean, i hooked it up exactly the same twice and one time it worked fine with the MMM and the other time nothing on the HV. i also have test this with the rx and the same thing happens. everything is fine when i hook to my MMM but nothing happens when hooked to the HV.
castle hasnt responded yet to any of my calls or emails. maybe i will hear back tomorrow.
edit: so i checked the sticky with the led definitions and there is not a definition for a 1 second red blink and then nothing. i take that to mean there is something wrong. thanks for your help though metallover. even now i am still open to more ideas. i guess i just want to hang on to the hope that its just something i am overlooking so i dont have to send it in and wait 2 months.
Jammin SCRT10 Neu 1512 1y
