Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.12.2010, 04:50 PM
If your intent on making a slot in the chassis, drill the inside perimitter of the hole with a 1/8" drill bit till the chunk falls out and finish with a metal file. Shouldn't take but 15-20 miutes and a couple beers.
JThiessen
JThiessen's Avatar
01.12.2010, 09:08 PM
Scribe your lines on it with a utility knife, then use your dremel to cut as close to the lines as you can. Then use a fine file to finish the slot. You can also just use a drill for the extreme ends of the slot (use a drill the same dia as the slot is going to be).
I use these wheels on my dremel - works much better than the standard ones. http://www.amazon.com/Dremel-EZ456-2...3344771&sr=1-4
They also come in a kit
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7
thzero
01.12.2010, 10:25 PM
Those are the ones I've used to cut aluminum. I have also found the version for plastic works well on thick lexan bodies.
01.12.2010, 10:44 PM
That's almost $2 a wheel!!! Do they work that much better?? I know I hate changing wheels, so the convenience is definitely a plus.
JThiessen
JThiessen's Avatar
01.12.2010, 11:00 PM
In a nut shell - yes. I used to go through 2 or 3 wheels per cut job. Now I change wheels about every 4th or 5th job.
01.12.2010, 11:59 PM
sweet, thanks
Fast5sRevo88
01.13.2010, 04:39 PM
http://www.amazon.com/Dremel-EZ406-C...3344771&sr=1-7[/QUOTE]
Are these better than the fiberglass reinforced ones?
JThiessen
JThiessen's Avatar
01.13.2010, 08:04 PM
I'm not certain which ones you are referring to? I've only used the ones I linked to and the standard little brown ones that come with most dremels.
Fast5sRevo88
01.13.2010, 08:32 PM
I was referring to the ones that are about 2" round, they are brown, but they have a fiberglass webbing on them.
