Soro
Flux Fan
Soro's Avatar
10.08.2010, 10:51 AM
In order to use the servos on the same signal, you just need a Y-harness to plug them into and then plug into the receiver.
Depending on which way the servo makes the wheels turn, you may have to rotate the servo to get the correct swing in the rear.
Is that all
Savage Flux 5mm TCS TVP with 8 Big bore shock conversion : Savage Flux XL TCS TVP with 4 IRC shock conversion
bryan
bryan's Avatar
10.08.2010, 11:58 AM
I dont know what transmitter/reciever youre using.You may be able to use an aux. channel.That way you will be able to fine tune the rear steer to your liking.
