thzero
02.23.2011, 12:28 PM
linc, how long is the LST axle? And what is the distance from the pin hole to the outer bearing face? And what diameter is the pin hole?
Thinking about trying to use some LST/LST2/etc CVD axles on an RC8T to be able to run the proline 23mm hex adapters; or attempt to use my 4mm sleeve + 24mm Baja hubs...
