Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.09.2012, 10:07 PM
Just grind the set screw flat so it will a bigger surface are to "grab" into the shaft. I do this on all my set screws and no problems so far.
I'll try that now before get into doing anything to the shaft. I have plenty of set screws that fit. :)
BTW, the diff looks straight in the 2nd two pics I posted. Can anyone else see any angle?
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
bruce750i
bruce750i's Avatar
01.10.2012, 04:55 AM
The top of the spur appears to be slightly leaning away from the motor mount. Is it me or has your pinion been losing some weight?
brian015
brian015's Avatar
01.10.2012, 08:13 AM
+1
Your spur does not appear to be exactly vertical - this means your mesh will not be perfectly aligned - and your pinion will be forced toward the end of the motor shaft and eventually come loose.
