1717 Possible to snap motor shaft from too large pinion?
01.17.2012, 11:05 AM
Originally Posted by
anunaki
Can you explain what a side load is in detail.
If you set the spur/pinion mesh too tight, the shaft tends to "push" against the shaft bearing (especially the front one). Therefore, a constant load on a bearing spinning that fast can cause premature wear.
Visit BrianG's homepage!
Find all posts by BrianG
Off
