MMP w/sensored motor
Drifted Demon
MMP w/sensored motor - 01.27.2010, 04:05 PM
Righto guys. Ill be purchasing the Slice chassis for my slash, & because the tranny is reversed, ill have to reverse the throttle position. But because ill be using a sensored motor in SmartSense mode, will this still work with a sensored motor?
01.27.2010, 04:28 PM
Not 100% positive, but I believe the link software item "motor direction" will still work.
Marvin
THE Paranoid Android
Marvin's Avatar
01.27.2010, 07:50 PM
Yes it does - I had to reverse the direction for my Ve8 - I'm using the Tekin T8 and MMP. Just reverse motor direction using Castle Link and you'll be set.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
sikeston34m
sikeston34m's Avatar
01.27.2010, 07:53 PM
Hey Marvin,
What T8 Motor are you running? How's that working for you?
I've been wanting that same setup myself.
I've been running a Novak 6.5 Sensored Motor with my MMPro and it works great.
Marvin
Marvin's Avatar
01.28.2010, 04:09 AM
Hey,
I'm running the 1400KV on 6S. I've got 3 additional caps (35V, 220UF, 105° each), and I'm not using the onboard BEC. I haven't had much chance to test it yet - it's too wet and cold over here, not to mention that there are no 1/8th races going on in the winter.
It is powerful enough to wheelie, and is pretty quick, so it looks good.
Lauri
01.30.2010, 12:20 PM
Hi,
I'm now a bit confused. When I run sensored with CHEAT, does the Sensorless Motor Timing (in Castle Link) have any effect?
Drifted Demon
01.30.2010, 06:50 PM
I think so because that would be Timing over the whole rpm range whereas CHEAT alters timing at a certain rpm & above...
Lauri
01.30.2010, 07:33 PM
Anybody has some solid information about it? When I run sensored with CHEAT, does the Sensorless Motor Timing (in Castle Link) have any effect?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.31.2010, 06:21 AM
No. Cheat mode requires sensored only mode.
Area 52 Ranch Raceway
T.R.C.R.
