You can sleep in a car, but you can't race a house
Getting the Pinion to stay on the motor shaft? -
01.09.2012, 09:14 PM
Anyone have any advice on this "fun" problem? Running 3S or 4S its not a problem. However put 6S on the truck and after about 2-3 minutes of running the pinion will walk itself off the shaft. Thankfully I've been lucky in that each time its done it, it hasn't stripped a spur or pinion. no real wear/tear honestly. Also, my battery tray keeps the pinion mostly on the shaft so it doesn't get lost. An unintended benefit of the way I built the conversion.
I've used globs of blue loctite. Waited 24hrs before it cured. I've replaced the set screw thinking maybe the old one just just not holding.
I've tried with the pinion in both directions.
If I had any red loctite I'd be using that now, but I'll be buying some tomorrow simply because i'm tired of only being able to run 2-3 minutes before having to "fix" the truck.
I had even considering marking where the set screw sits and cutting a tiny indentation in the shaft so the set screw can sit "in" the depression. But I don't want to cut shaft if I don't have to.
If I thought I'd never have to take this motor out of the car ever again I might even JB Weld that thing on there. I just want to play with my new toy, not fix it constantly.
- 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
- Jammin X1 CRT Pro, MMM/1717, 6S
- Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
- Hyper 10TT, MMP/1410, 3S
- TL Mini 8ight, stock, 2S
01.09.2012, 09:33 PM
The only time I had trouble with a pinion coming off like that was when my motor mount was misaligned, so the pinion was meshing at a slight angle with the spur. This produced a force on the pinion that pushed it outward toward the end of the motor shaft and it came off regularly, until I fixed the misalignment.
01.09.2012, 09:39 PM
I'll have to look at that. It didn't look crooked, but i also didn't consider the possibility that it could be crooked. I figured when the motor was tightened down it would flatten itself out as long as something wasn't between the motor and the mount.
01.09.2012, 09:40 PM
In my case, it was the motor mount itself that was misaligned, not the motor to the mount - if that makes sense.
01.09.2012, 09:43 PM
I don't think that will be the case for me then. I'm using the factory drilled differential holes. All I did was switch the direction of the diff. So it should be fine.
01.09.2012, 09:54 PM
If you look in your other thread about the build of this truck.
You can see the diff is not lined up with the motor mount end of it.
This could be your problem.
Peace!
Country
Help support the
Rc-Monster
Buy here
01.09.2012, 09:55 PM
Peace!
Country
Help support the
Rc-Monster
Buy here
01.09.2012, 10:02 PM
What I did with my MT4-g3 is dremel a small divot in the motor shaft where the set screw contacts it.... This let's the set screw sit a tad deeper. Red loctite should also work. There are also pinions with two set screws that will do the trick..
Here's one
http://www.ebay.com/itm/NEW-Tekno-R-...6#ht_626wt_698
01.09.2012, 10:05 PM
That was the test fit with the spacers underneath the differential. Those are gone now because the chassis was clearanced so the spur didn't bottom out.
Here are two new pics from that. It looks like the pinion slipped a bit before I tightened it down in the opposite orientation to the way I had it before. Thats as far back as it will go with the set screw tight. I'll swap it again.
01.10.2012, 12:06 PM
Can you get the pinon to line up better (flip it around)? Having the spur mesh with the edge of the pinion may also cause it to be forced off. Just another thought.
01.10.2012, 12:12 PM
That was my alternate attempt the pinion is 180* from that. The way its installed now is opposite that picture.
Supermaxx
01.09.2012, 10:06 PM
Just grind the set screw flat so it will have a bigger surface area to "grab" into the shaft. I do this on all my set screws and no problems so far.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Reason: Spelling and grammar.
01.09.2012, 10:07 PM
Originally Posted by George16
Just grind the set screw flat so it will a bigger surface are to "grab" into the shaft. I do this on all my set screws and no problems so far.
I'll try that now before get into doing anything to the shaft. I have plenty of set screws that fit. :)
BTW, the diff looks straight in the 2nd two pics I posted. Can anyone else see any angle?
01.10.2012, 04:55 AM
The top of the spur appears to be slightly leaning away from the motor mount. Is it me or has your pinion been losing some weight?
01.10.2012, 08:13 AM
+1
Your spur does not appear to be exactly vertical - this means your mesh will not be perfectly aligned - and your pinion will be forced toward the end of the motor shaft and eventually come loose.
