"Out of spec" enthusiast
MMM runs Novak better than Novak -
09.02.2008, 10:06 PM
I just tried my MMM for the first time today and I am glad to report that my HV 4.5 motor ran better on the MMM esc than it did on the HV-maxx esc.
Throttle was just as smooth and so were the brakes, only cogged once, but instead of getting about 12 minutes of runtime like i did with the novak esc, I got over 15 minutes of runtime, taking temp readings every now and then.
The only thing I noticed was that the throttle would cut out for split seconds at a time occasionally during acceleration, but I believe this is a radio interference issue. My mamba max does this some times and rarely, my novak esc does it as well.
Overall I am very satisfied. Everything ran about 10 degrees cooler and that was with 10 degrees timing. Gonna try 0 degrees.
Motor 172
Esc ??? fan only came on once breifly during run so 150? Case was 106
Battery 118
Setup is the 8ight in my signature geared with a 9 tooth pinion.
09.02.2008, 10:09 PM
Another Novak shortcoming... How surprising.
09.02.2008, 10:25 PM
Did you just hook it up with out the sensor wires? And what batteries were you using with this combo?
09.03.2008, 05:41 PM
Yep, no sensor wires. A Neu Energy 30C 4100 mah 4s was the battery.
09.03.2008, 08:44 PM
I'll have to give that a try, and see how it compares to the 10L.
Novak -
09.03.2008, 09:33 PM
mmm interesting,
Novak may have its shortcomings, but at least it runs most of the time unlike the Hiroshima MMM.
I know which one I would choose at present.
09.03.2008, 10:22 PM
Originally Posted by NZ Monstermaxx
mmm interesting,
I have smoked many more novak escs that MMMs.... All of my novak failures were due to faulty components, and all replaced under warranty. There is no such thing as 100% success rate, just check your underwear and see if you get the "wiping the ass" thing right every time...
And welcome to the forum... Like we need another Brit???!!!!
09.03.2008, 10:40 PM
When they smoked did it look like a smoke bomb?And how many Novaks have you had?How many times did you wait for months for a replacement?I have never seen a thread on modding a new Novak to make sure it would work. Sorry I'm a little Novak happy right now as it seems like the only dependable system I can find.Hopefully Losi will change that once they release there Novak based sytem :)
That's All Folks!
09.03.2008, 10:44 PM
"Hiroshima MMM" nice first post NZ  welcome to the forum.
09.04.2008, 12:22 AM
09.04.2008, 12:42 AM
Lets see, had a losi xxx-t bl truck that died about 2 mins in to the first run. Had a few ss escs mysteriously drop a few fets and cogg terribly. My crawler esc does not work properly, no drag brake and weird reverse issues. I have had good success with the 2 gtb escs I have, although a friend had issues with his. Novak fans lose blades quite easily. I have not owned a hv esc, just cannot bear to part with that kind of cash for something so poor...
Novak service was decent, around 2 weeks to get replacements. Many people will mod the hv escs to handle a single pack (short sighted by novak to assue 2 packs would be used). And the internal bec cannot be used with a single pack.
I have had better luck with CC products. I have only smoked one MM and that was trying to run it with a 7xl, geared for 55mph. Worked fine till I got a rock stuck in the spur and over drawed the esc till the solder melted...
Have a v1 MMM that has 6+ hours on it and still working. I have 2 v2 MMM that I will be testing too.
Just trying to say that every company/product has issues. Plus the novak hv setup is very gearing sensitive, and not powerful enough to push a MT or truggy fast. Will work fine with a buggy, and the new hv pro is a step in the right direction. Not going to compare to a 1515 1Y and a MMM. The novak will run with maxamps packs though
09.04.2008, 08:51 AM
I think one of the issues Novak faces is that so called "newbies" see comments like this posted all over the place, and assume that the HV systems are slow, and therefor purchase something else. Then you get the one or two people who actually purchase one, use it, and post that it runs great. They inevitably get flaming arrows shot at them for stating such an atrosity, since "everyone knows the HV is slow". I would have to guess that there are in fact more HV systems in MT's than any other one product, and yet you see so little posted about actual problems with them (very little here, a few more over on the Traxxas board). The only place you can use more power is on long straighter runs - on a track, anything more than an HV is wasted power to the general brushless driver. I am struggling with getting my Revo (and the driver!) to be able to use the power it has.
Something, anything, nothing
09.04.2008, 09:25 AM
When the HV system came out, it had its fair share of issues as well. When they started with the 4.5, when used with lipo is was melting controllers left and right. Until novak ironed out the kinks, they had remanufactured units availble in their site constantly. My issue with the novak is not so much power as it is expensive for what you get and way behind the times. I mean they just got a built in LVC, the programming is still minimal, and the performance is only marginal.
I have also melted two Novak brushed ESC's set up well withing spec and it took near two months both times to get them replaced.
Nobody is impervious to failure and I think linc's analogy of the underware is spot on pun intended!
09.04.2008, 10:00 AM
Well, not to point out the obvious, but most MT owners do not race, so almost all of those HV systems are hanging out in bashers...
In a mostly stock emaxx with the recommended gearing I am sure that the HV is fine. Keep the weight down and the gearing conservative and it will perform as advertised. But that is it, you buy it and install it and that is the end of the HV. No programability, or upgradability. Plus it is a bit pricy considering the competition. A MM is much cheaper, can run a variety of motors, and has full adjustability. Personally, I have enough driving under my belt that a vehicle that does less than 35mph is boring, and I have most of my collection geared for 45mph now.
For an entry level bl system the HV is fine, and it is a viable alternative for a race bl setup in an 1/8 buggy, especially considering novak makes conversion kits for buggies. Still too expensive for what you get, IMO...
HAHA, good one!
09.04.2008, 11:19 AM
I think we may see the price point come down in the near future. About a year or two ago, you really didnt see many mainstream brushless conversations except on this site. Now, even on the Traxxas site, there are probably about 40% running some form of brushless. Competition will drive that price down. But until someone else offers a plug and play setup, they are still the only game in town in that regard. CC's offering, once they get it to actually run, will likley be a much better system for the money.
